メインコンテンツにスキップ
A Color Document Scanner by Epson.
3回答 すべてを表示
Jams when scanning Drivers License
We use the DS 510 in our medical office. The scanner used to scan both Insurance cards and photo ID's with no problem, but recently it jams on only the Drivers License photo ID. I have looked and found no mechanical issues. If we place the ID longways in the scanner it will scan, but then we spend extra time rotating the ID for our files. Time consuming. Any suggestions?
Things I have tried:
Adding post it to the back side of the ID - still jams
Moving the mult page and cont feed button - still jams
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
6件の回答
最も参考になった回答
I ran into this too. There's a setting that can detect double-feed (thick document) situations. When the setting is on, cards I scan will jam. If I turn it off, I can scan cards. Good luck!
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
This fixed it. I created another preset job titled Card Scan Double Sided. I followed the configuration as shown above from Ed. Worked perfectly. Thanks Ed
さんによる
コメントを追加
Thicker or stiffer stock of the ID's maybe the issue, the unit may not have been designed to feed it.
The other possibility is the motor drive is getting tired or worn, can you try out a second less used unit?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Could it be a security measure to stop people from creating fake IDs? Ive heard they have a way of doing this with cash notes.
さんによる
コメントを追加
Have you looked at you scanner software to see if you can rotate the image after scanning and before saving?
R
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
We have this same issue with a DS-530 Scanner. The manual states to place the card horizontal and not vertical. However, the same manual also states that the card thickness capacity is .050” but the cards that get stuck are only .027”, measured with a micrometer caliper. I have opened a ticket with Epson for this.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have noticed this for the new TX driver licenses that have an engraving. You can feel it with your hand. The old ones that are smooth are still working fine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you put your hand in first and push the feed rollers (the ones closest to you) you'll feel them adapt (for thicker documents I understand). Then put the ID in (and align the guides. It should feed it through just fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shannon Freeman LAC さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 32
過去 30 日: 134
今までの合計 3,852
