メインコンテンツにスキップ
様々なブランドから製造されているラップトップPC(ノートブック)コンピューターの修理ガイド。
18975回答 すべてを表示
Is 50°c normal for a laptop hard drive?
My laptop has been running hot, and I noticed that the hard drive was running at 50°+. My desktop's hard drive never hits 30°, but of course it isn't the main drive, and it has good cooling. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
@pccheese, George A. I was curious about this also, so I checked out quite a few forums and they were all pretty close to the same conclusion on HD ideal and safe operating ranges. Look's like yours may be running on the high side of acceptable. Maybe also look up your particular HD and it may have actual heat range specification. Found this info. at the link below which you should check out as it is fairly informative, talks about failure rates, etc..
What is a Safe Hard Disk Temperature Range?
Drawing conclusions from the Google paper, smaller independent studies and tech forum users:
Less than 25°C: Too cold
25°C to 40°C: Ideal
41°C to 50°C: Acceptable
More than 50°C: Too hot
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.buildcomputers.net/hdd-temper...
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Well... I guess I'll have to find some really thin heatsinks. Or something else.
さんによる
P.S. I press the "helpful" button whenever I see a post of yours. I don't need to read it to know it's helpful.
さんによる
@pccheese, Thanks George, perhaps a cooling pad.
さんによる
コメントを追加
Found the issue. In the BIOS I had the HDD setting set to "High-performance". I'm not positive but I believe this is a slight overclock in timing for the hard drive so the motor will spin faster and increases voltage too. After I turned it off it ran cool as it should.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
George A. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 155
