メインコンテンツにスキップ
What 's the kinds of stones I can use and how can I drill it?
the process of friction is not so clear
please increase the length of it make it clear
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
@kassab - Starting a fire without a match can be done many ways!
  • Flint and steel which is by far the easiest to carry with you when hiking.
  • Friction using two things that when rubbed at a high speed create heat. Often you don't have the needed parts or a means to create them to do this (which I think was your core question here).
  • Sunlight using a magnifier (to concentrate the light) which can be a lens made from glass or plastic or even use water! Using a sheet of plastic, a broken bottle or, even a shiny metal pan. Dependent on the Sun being available.
  • Chemical which creates a reaction of fire or high heat. Not very practical when lost.
In all of these you still need dry tinder & burnable items for fuel.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Take a bleeding heart liberal democrat and rub her up against a Republican. You'll quickly understand the concept of friction. Just ask my currently estranged girl friend if you can get her to shut up long enough to even get a question in..
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sulphur Dioxide (Brimstone) and you don't want to drill it.
さんによる
コメントを追加
回答を追加する
seif kassab さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 319
