メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Vostro 1400は、中小企業向けノートパソコンシリーズの1つです。2007年7月に発売された14インチ画面搭載のデバイスです。
Battery life is short
I have had my Dell Vostro 1400 for almost a year now and the past few weeks the battery has not been lasting long. I will charge it all the way but still the life will only last for about 4 hours. I went and bought a new charging cable so I that is not the problem. How do I know when it is time to replace the battery?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
The best course of action would probably be to take it to an electronics shop and have them look at it, but given that it has such a short charge life it is most likely time to get a new one. You can find a replacement guide for the battery here.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Its pretty obvious the battery is going as its probably almost 10 years old. and 4 hours is still a decent charge as it probably didnt get much more when it was new. If it was 1 hour or less, get a new one but this one should last for another year or 2 yet.
さんによる
コメントを追加
@kennedyhallmark,Kennedy, This is directly from Dell official site. All rechargeable batteries wear out with time and usage. As time and cumulative use increase, the performance will degrade. For the typical user, noticeable reduction in run time generally will be observed after 18 to 24 months. For a power user, reduction in run time generally may be experienced prior to 18 months. We recommend buying a new Dell laptop battery when the run time does not meet your needs. See links below for more info. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.dell.com/content/topics/globa...
https://www.howtogeek.com/172362/how-to-...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How do you know when its time? Its time when it dies within an hour or so. The fact that it lasts 4 hours is still pretty good for a 10 year old laptop. When the battery lasts less than an hour thats when its time to replace. You should have replaced the battery as the charging cable was fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kennedy Hallmark さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 492
