How do I upload photos from the camera to my computer?
I'm not sure what to do after I plug in the camera to the computer in order to see the photos on my computer.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@ariel91 ,Ariel, You did not state your computer make/model or which windows version,etc.. So find some what generic ways to transfer and view your pictures from camera. Link #1 is for win7, link #2 is for win8, link #3 is for win10. The 4th link is for your camera's manual, software and trouble shooting. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://support.hp.com/us-en/document/c0...
https://support.hp.com/ca-en/document/c0...
このアンサーは役に立ちましたか?
Most Cameras read as Removable Drives, much like a flashedrive. If you plug it in, most likely you will have to go to "My Computer" and find the device in that folder.
However, you may have to download the utilities to do this. that is a common issue with older cameras, where you would need the utilities off of the internet. (They normally come on disc, but no one keeps those glorified drink coasters.) the utility can be attained through Samsung Support.
another option is to remove the memory card, and put that into a card reader. (This is your most simple solution, but requires your PC have a media card reader. Plug in the card, and it should ask you what you want to do with it after automatically installing drivers. if it does not, you would have to go to the "My computer" Page to find it
このアンサーは役に立ちましたか?
One way to do so would be to remove the SD card from the camera and place it into the SD card slot of the computer used and simply copy and paste or drag and drop the photos from that SD card to the computer. Once that job is done, simply remove the SD card from the laptop and place it back into the camera.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 488
