メインコンテンツにスキップ
モデル番号A1706/EMC 3017ー2016年11月発売。この13インチのMac Book ProはOLED Touch Bar搭載です。デュアルコア"Skylake" Intel Core i5 CPUと4つのThunderbolt 3ポートが特徴です。
239回答 すべてを表示
Display Assembly Replacement Repairability
I was wondering how difficult is was to remove and re-insatll a new Display Assembly on the new MacBook Pro Touch bar. I noticed hinges in the middle of the screen. Do you have to do anything with the Touch Bar in order to remove the Display>
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Right now we don't have any guides prepped as the system is just to new and parts are just not available yet.
Depending on what happened it might be covered under warranty. Can you tell us a bit more here?
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Just trying to be prepared. We fix apple computers on a daily basis. I have had a couple calls about folks dropping thier Touch bar macs and smashing the LCD which obviously the entire assembly needs to be replaced. Watching the Teardown video i did not see the Display was removed. Was just seeing if iFixit ever removed the display before and if so, did they have to disassemble the touch bar at all to get to the hinges holding the Display to the Top Case.
さんによる
More likely they yanked the USB-C power cord pulling the system to the floor ;-}
A friend of mine who works for Apple told me he has already seen 4 systems messed up because there's no MagSafe anymore. They're becoming expensive paperweights.
さんによる
For reference: How do I replace my screen on my MacBook Pro? You're not the only one ;-{
さんによる
VERY challenging and parts are not affordable, I think I counted 30 screws for the display touch bar area, total nightmare
さんによる
コメントを追加
回答を追加する
Store Manager さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 664
