My phone keeps flicker yellow on n off
My gelesy s5 keeps flicking in n out yellow how do i fix it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Usually this happens right after the phone is dropped. If it is then you will need to get the screen replaced.
このアンサーは役に立ちましたか?
*Hello, if you have an Android device, and if you enabled Developer Mode and selected an option that gives you a visual screen update flash, this is why. Please turn off the "Show Screen Updates" and/or "Show GPU view updates" and/or "**Show hardware Layers updates"
*Please note, these instructions only apply to Android Devices, if you do not have an Android device, or if your phone has visible damage, the screen's pixels may be disfunctional.
このアンサーは役に立ちましたか?
My phone did the same thing and turning off auto-brightness fixed mine.
このアンサーは役に立ちましたか?
If you continue to have people give their opinions on fixing your phone it would help tremendously if you can understand what that person is saying, I can't understand what the &&^& these @%^$$@$# are saying, get a person that doesn't sound like they just learned English as a 4th grade refugee!
Stop with censorship, people know what I meant when you add these $%^&**^^ crap to hide my potty mouth...you &&^&^$ @%^$$@$#!!!
Mt phone is half yellow and it glitching then turns black and the top half of phone is normal
このアンサーは役に立ちましたか?
Hi Mackenzie,
That sort of behavior is almost always a result of a damaged or defective LCD screen. To fix the problem you'll have to replace it. iFixit has a guide showing you step by step how to replace the screen and can even sell you the part you need if you want!
過去 24時間: 0
過去 7 日: 8
過去 30 日: 37
今までの合計 12,982
