メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
Strange blue lines on my MacBook
Hi,
My MacBook Pro was having problems. Apple reseller diagnosed a broken logic board €1000. I went to an other store and they replaced the video card.
The mac is working but now I'm having this strange issue (this problem started before the mac was fixed)
I'm having blue lines (see pictures)
in different websites (not always, sometimes I can work for hours without any problem) the only thing I can do when this happens is power off the mac with the power button.
Is this a software problem or is there still a hardware problem.
Update (04/06/2017)
On the invoice is noted VGA repair. So not sure it was the graphics card that is changed
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Was it repaired under the program?
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
When was it6repaired?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
That looks like the mouse is "selecting" text on the screen, does this only happen on web pages?
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Good Point! I didn't magnify the image (my bad)
That's it! The selection action is engaged. So he has a trackpad problem where the click plate is not correctly set or the ribbon cable is not seated. Or, lastly there was some liquid damage on the trackpad logic.
さんによる
I would remove the trackpad ultrasonically clean it and inspect the ribbon cable and replace if necessary.
さんによる
Okay, but why is the screen stuck when this happens. I need to power down the mac with the power button.
さんによる
If it is in a state of constant "selection" it could be locking up the Mac, just a thought
さんによる
@idoc open this up, disconnect the trackpad, then try and use it with a USB mouse. If you are no longer experiencing this issue, it will be related to the trackpad.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Mattis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 898
