JBL Xtreme Speaker Busted
My JBL Xtreme speaker busted I guess from playing to loud of course. Any way to fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@travisanthony3,Travis Anthony, I do not own this device. You can try a reset, while the device is powered on, press and hold the ‘Connect’ and ‘Volume Up’ buttons simultaneously for 5 seconds to factory reset the device. Did not help, you will then have to proceed to disassemble the speaker to locate/test/bad components/ loose connections/ ripped speakers, etc.. Below are links to show disassembly and 2nd link is to trouble shooting JBL XTREME.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
Can it go Louder
I had same issue with distorted busted sound. I did the reset and now it won't turn on at all and my speaker no longer works.
過去 24時間: 2
過去 7 日: 13
過去 30 日: 57
今までの合計 12,699
2 件のコメント
What does "busted" mean? Is the speaker cone torn?
Russ Walden さんによる
I mean I guess! Just every beat sounds horrible now! Like the vibration sounds badd
Travis Anthony さんによる
