メインコンテンツにスキップ
Googleから発売された最初のAndroidスマートフォン、Pixel XL(モデル番号はG-2PW2100)は2016年10月20日に発売されました。5.5インチのAMOLEDディスプレイ、3450 mAhバッテリーが搭載され、32もしくは128GBストーレッジが選べます。
WiFi Antenna Replacement Procedure For Google Pixel
after getting the phone wet, I am having issues and facing a WiFi struggle after 3 hours later. it will not connect unless the phone is actually on the router itself. I'm not sure if its because its still wet, or that it actually got damaged completely but i would like to know is there anything i can do to repair this myself, and where the antenna is located and if there is any parts to replace this online or on any stores.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
How did you solve this problem? I have exact same problem on mine. Any help from your side will be really appreciated
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Brandon Tenney, Antenna seems to be a chip soldered to the board(seen in step 11 of the guide below).
If the phone was not treated properly for water/corrosion damage Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Google Pixel XL Teardown
Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Brandon Tenney さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 47
今までの合計 6,733
