メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Week wifi connection after battery replacement
I replaced my iPhone 6 battery a month or so ago, and ever since then my phone has been having trouble picking up wifi unless I'm very close (about 10 feet) away from the router.
The wifi is not greyed out.
I've also noticed some poor Bluetooth connectivity when I'm playing music in my car and so location issues with my Maps GPS since the battery replacement, but I don't know if these issues are related
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
I have the exact same issue!
さんによる
The Apple Store replaced my iPhone 6 battery and now I have to be in front of my modem to receive a signal. None of our other devices have this problem so it must have been damaged during the replacement.
さんによる
コメントを追加
6件の回答
最も参考になった回答
Sounds like you are having one of two issues. The first, and probabaly not likely is that the wifi antenna got unplugged or is failing. The second and more likely thing is that the wifi/Bluetooth chip on your motherboard is loosing its connection causing you to have a weak signal. In order to do this repair, you will have to micro solder a new chip onto your motherboard. Not the easiest of repairs that's for sure, but can be done.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
I find out sometimes that the L shaped antenna cable that plugs into the top left of the logic board can go bad like hard drive cables in a unibody MacBook.
Sometimes it's just screws needed to be taken in and out for the wifi antenna stuff.
さんによる
I doubt the battery replacement caused this issue. It seems more of a coincidence that it happpened near the same time as the repair.
さんによる
Well I had the same coincidence! My WiFi worked just fine until Apple replaced my battery!
さんによる
I have same thing happen, Genius Bar respond me battery is not related to wifi antenna and they can’t replace it. They suggested me to replace phone on $439.
Don’t know what to do?
さんによる
Dito. I just replaced my battery at Genius Bar and having WiFi problems.
さんによる
2件以上のコメントを表示
コメントを追加
You probably need a new wifi antenna. It is a common issue. Sometime it could be that it got unplugged
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cableの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
https://cepmarket.com.tr/urun/iphone-wif...
Türkiye’de yaşıyorum bende de wifi sorunu vardı, bu firmada yaptırdım, şu an için sorun yok, dilerim bozulmaz
さんによる
コメントを追加
I have the same issue after replacing my battery and it always ended every month extra charge for my data…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had/have this same problem and after tearing into the phone to investigate, found that I had accidentally broken the wifi/bluetooth antenna connector (the S-curve piece that connects the antenna to the logic board). I imagine this is an easy accident to occur during a battery change, especially if the adhesive doesn’t off easily.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you fix it? How did you fix it?
さんによる
コメントを追加
Next day after 6s battery replacement wifi down load at 0.7 mbps says a speed checking website. Data via sim is 150mbs and wifi modem says should be above 40mbs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same here! Genius Bar Replaced the battery and now poor WiFi. Coincidence? I think not!
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
Go to Genius Bar and argue with them otherwise lodge the complaint formally and deal with them. I got new replaced phone on free, after fighting back for 2months.
さんによる
コメントを追加
回答を追加する
Anna Spuhler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 7,290
