メインコンテンツにスキップ
Repair guides and support for your LG TV.
1343回答 すべてを表示
Can someone fix the HDMI 2 port, which has pushed in?
The HDMI 2 port has somehow become mangled; it ;looks like it has been pushed in, and I don't know how to pry it out or whether prying it will damage it. Are there people I can hire to do this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
yes what exact model is your TV?
さんによる
If you want to try to fix this, you probably need to take the tv apart. And if it is bent, its pretty much screwed anyway as some pins probably broke which are a pain to fix
さんによる
Bless you! I will look for a computer repair or TV repair person. Thank you so much.
さんによる
コメントを追加
1 件の回答
ベストアンサー
yes, Yes the HDMI 2 port can be repaired, yours could be soldered directly to a board which takes some skill to reattach if undamaged or replace if need be. Any good local TV repairman or computer repair shop can probably perform this task. The link below will give you an idea of what is involved in the repair of a loose HDMI port. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=lxJJ-9xP...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
yes, did this help answer your question.
さんによる
コメントを追加
回答を追加する
yes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 33
今までの合計 6,643
