メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
iMac Backlight Controller Location
Hi – I have a 2015 iMac which I have replaced the thermal compound for, turning it back on I note that the hottest part of the system is the sensor 'Back light controller proximity temperature' which is at 48C at idle. I am afraid to push it. Does anyone have any idea where this sensor is located? Along with the CPU and GPU compound I have just replaced the thermal pads on the VRAM and am concerned these new pads may not be performing as needed. Here are my current temps:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
As far if temps are, 50C isnt bad. For cpus if you get 60C thats great any more and thats a bit on the hot side. Also have you tried other programs that might give you different results? Ive had a program tell me some absurdly low voltages for my psu but it was wrong so try a few different programs and then see if the numbers match up. But 50C is only 122F which isnt horrible
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Charles さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 132
