メインコンテンツにスキップ
Smartphone by Huawei, released April 2015. Includes models Y625-U32, Y625-U21, Y625-U51.
22回答 すべてを表示
My huawei y625 has Stuck in headset mode completely.how do I fix this
I plugged An earphone from my subwoofer into my phone whilst listening to music..and when i unplugged it,the headset mode stucked on the screen...its been four months right now i dont know how to fix this..please i nees help coz i can not make a call amd hear a voice nor listen to music again because there is no sound
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Have you tried hard booting your phone?
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
Try inserting the headphones with the microphone attachment accessory into the headphone socket and then either make or receive a call to determine that you can both hear and be heard.
If you can it proves that the phone is working correctly and all that has happened is that the contact in the headphone socket, which informs the audio controller that the headphones have been inserted, has got stuck in the operated position.
You could try gently inserting and removing the headphone plug a few times (gently wiggle it from side to side when it is inserted- stress gently) to see if this will free the contact. You will know it is free when the headphone icon has gone from the screen with the plug removed.
If this doesn't work then the phone will have to be opened and the headphone socket will have to be replaced as it is faulty.
Here is a link to a video which shows how to dis-assemble the phone. At 2:29 minutes into the video the headphone socket is clearly visible on the systemboard.
Because it is a SMD (Surface Mounted Device) removing the socket and replacing it with a new one is not a job for novices. You will need to have the requisite skill and tools to perform the work. You can cause more problems than what you had before you started if you do not know how to do this.
I recommend that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Thanks jayeff i wiggle wiggle wiggle and
Solved
さんによる
コメントを追加
Try hardbooting your phone. You can do this here-http://www.hardreset.info/devices/huawei...
Hope this helps and good luck fixing!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ahmed kibwana さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 19,528
