メインコンテンツにスキップ
Kindleの大型モデルDXは、大型の9.7インチのe-インクディスプレイを搭載しており、日光に当てられた本物の紙のような感覚です。
Is there any way to fix a broken button?
Is there any way to fix a button that has physically broken in half? It is the main toggle button between the menu and back button on the Kindle DX. If it cannot be fixed, is there a new model that would be recommended that is similar. I have very poor eyesight and this model has been very good for me because I can make the font very large and it is not backlit.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
This is a very common problem according to the many DIY "fixes" posted on the internet. Amazon WILL NOT issue a recall or a repair for it.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Heather Neilson , The button should be replaceable. The first link below shows how to disassemble the device to access the button to change. The other 2 links may have a replacement button for you or you can also do a search using your make and model replacement buttons. If not wanting to tackle the repair pop into a good local cell/computer repair shop, have them take a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.rapidrepair.com/Merchant2/mer...
http://www.powerbookmedic.com/xcart1/hom...
http://www.powerbookmedic.com/Amazon-Kin...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Heather Neilson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 1,266
