メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
4.3インチタッチスクリーンとBluetoothを搭載したポケットサイズのGPS受信機。
It's not turning on
I have previously replace the battery front screen and updated the maps & it was working fine, but for some reason it won't power on. Left it on charge but it seems like the charge may not be registering with inside battery. I can see the green light on but nothing coming on. I left the device working in the glove compartment of my car so not sure what's wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Raja Minhas , If you are not sure the device is taking a charge try another compatible charger to see if that is the issue. If charger is good remove the battery(1st link)below and see if it is fully charged use a DVOM, if battery not charged could be a faulty battery or charge port issue. Blow/pick out any dust/lint/etc. from the charge port and look for bent pins and straighten carefully with a tooth pick. If battery is OK and charged try a reset 2nd link will tell how. If device happens to be under warranty return for repair/replacement/refund. Good luck.
https://www.youtube.com/watch?v=NcbebExQ...
https://www.gpspower.net/tomtom-tutorial...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Raja Minhas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 579
