First I would notify eBay that it is a locked machine. (it may be stolen).
Users who require higher than usual security measures often set a firmware password on a Mac, which requires that a password be entered before the typical OS X boot sequence begins. While these low level passwords are quite secure, but that higher security also means a forgotten firmware password can be a significant problem. Nonetheless, if you wind up in a situation where you or another user has forgotten a low level firmware password on a Mac, don’t panic, because you may be able to recover the password or bypass it using one of the methods outlined below. If all else fails, Apple can possibly help you too.
Do note that a firmware password is not the same as an administrator password or the general computer password used to login to a Mac. The firmware password appears immediately upon boot and is a gray locked icon, looking like this:
The Mac firmware password screen, that you forgot the password for
If the password you’re having trouble remembering is a general Mac login or administrator password, you can reset it with these instructions instead. Using the the Apple ID approach on boot is typically the easiest for modern Macs.
1: Try to Reset or Disable with Firmware Password Utility
You may be able to reset, change, or disable the firmware password using the same method you used to set the password to begin with, this requires booting into Recovery Mode:
Reboot the Mac and hold down Command+R to enter recovery mode
At the Utilities screen, go to the Utilities menu bar item and choose “Firmware Password Utility”
Select to turn the Firmware Password to OFF
If this is successful it will tell you the firmware password is off.
Disable firmware password in Mac OS X
Always check your caps key and num lock key before entering or modifying passwords, often mistakes are as simple as that.
Obviously you’ll need to enter a password to gain access to Firmware Password Utility, so why is this even mentioned, right? Because sometimes it works, maybe because of user error when typing the password to begin with. Yes you should actually try it.
2: Have Apple Unlock the Mac Firmware Password For You
If all else fails, you’re going to need to get ahold of Apple or an Apple Authorized Support center who can bypass and/or reset the firmware password using proprietary tools. This works on modern Macs, including the following (this list is not necessarily conclusive, always contact Apple directly if you can not remember your firmware password regardless of the Mac):
MacBook Air (Late 2010 and later)
MacBook Pro (Early 2011 and later)
MacBook Pro with Retina display (all models)
iMac (Mid 2011 and later)
Mac mini (Mid 2011 and later)
Mac Pro (Late 2013)
(Maybe others too, contact Apple to find out for sure)
You can contact the official Apple Support channels by phone, or schedule an appointment with a Genius Bar at a local Apple Store. Again, even if your Mac is not on that list, you should contact them.
In most cases, you will need to provide proof of ownership of the Mac which has a locked firmware password in order for them to unlock the computer in question. There may be exceptions for a variety of unusual circumstances, discuss those with them if necessary.
3: The firmware locked Mac is not included in the above list, and the password reset didn’t work, what now?
Wait, did you contact Apple Support or an Apple Authorized Support agent and ask them? They can probably still help you to unlock the Macs firmware login.
But if you’re the do-it-yourself type (like myself), then you will find that many older Macs, particularly those that allow you to upgrade and change RAM yourself, allow a hardware bypass to get around firmware passwords by physically removing memory from the computer and following the instructions offered here. That is a fairly technical process, which makes it appropriate for advanced users and systems administrators, but it should not be attempted by a person with novice computer experience. With that said, it does work, and I’ve had to use it myself before in a variety of interesting IT and troubleshooting situations.
8 件のコメント
@mr_icy did you have any luck?
Weed Abuser さんによる
Any news? I am also having the same problem. Not really sure if I can still recover the password.
Jayrus Asuncion さんによる
reset does not work neither does Command+Option+P+R to reset the PRAM, Command+R to enter recovery mode. only erasing pm area of chip by hardware method .
Sam Busak さんによる
It's like the brand new, out of the box, MacBookAir I bought from the PX. I locked it up, and took it into have it unlocked by Apple. Since I no longer had the sales slip, they said I stole the computer. That's Apple for you.
en.heim さんによる
Mine too. My mac is locked for no reason, I call Apple and they said my mac locked because it is stolen. I stole my own mac.
ilham ramadhan さんによる
3件以上のコメントを表示
