メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
No service after cleaning
Hi Guys.
OK i have some iPhone 6 with all have the same issue they came in with no sim issues which i resolved by cleaning the sim port but a new issue has arose.
The phones either keep saying searching or no service but if i clean the connector the antenna connects to the little push on in between the battery & dock connectors on the board i get a signal with 4G.
I try different sims in them & they work great until i reset them back to factory settings they then go back to searching or no service.
Would it be worth warming the connecter up on the board essentially reflowing it?
Anyone else have this issue & did you resolve it if you did how please?
Any help or suggestions would be amazing.
Thanks guys in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
What do you get when dialing *#06#
Do you see the IMEI or not
さんによる
I have not tried that yet didn't think it would be baseband issues as i do get a good 4g signal if i clean the connector. I did try heating the connector up 2 of them worked for about 10 mins the other just over 24 hours but all 3 have gone back to no service. i'll post back once i have tried checking the imei.
さんによる
Update yes all 3 are outputting an imei no while it has no service.
さんによる
コメントを追加
1 件の回答
Afther a factory reset did you connect it with Wi-Fi and adjust time to the correct location?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yes i have factory reset all 3 devices & i still get no service issue.
さんによる
afther a factory reset you have to connect to a wifi spot or ajust correct time and location otherwise it keep searching or display No service in the left upper conner!
さんによる
Is the device bent at all near the sim tray? Sounds like your having some hardware issues.
さんによる
コメントを追加
回答を追加する
Kenny Leonard さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 246
