Coconut Battery says Battery Failure Yes (83) with new battery
I am getting a battery failure #83 with a new battery in coconut, otherwise it's working.
Is the new battery defect and should be changed?
Update (03/16/2017)
here it is
It is just fine. It happens when u get an aftermarket battery.
このアンサーは役に立ちましたか?
@sherlock_holmes ‘It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts.’ -A Scandal in Bohemia
Can you back that statement up?
@sherlock_holmes sorry, your answers are partially complete nonsense. i want to point out one of your first answers: "Thats definitely an aftermarket battery. That means ur battery has 83% of life left with only one load cycle. Usually u should have over 200 cycles on a OEM battery. I would try to get my money back or trade it for a new one
16.03.2017 von Lord Vader's Finest Rocketeers " error code 83 has nothing to do with life left. you were mixing up % with codes and so on. please think twice and write nothing before nonsense. nethertheless thanks for your well-mentioned help.
What is the designed capacity have? And why was the answers and comments sent to just comments?
Is the bottom picture of the old battery?
Because there is an error code for that as well. Sorry btw. That was my bad. I don't know what I was thinking
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 5,015
I have written an email to Chris Sinai (from Coconut-flavor) and requested help from the horses mouth>
mayer さんによる
Thanks, that's kind!
heribert weber さんによる
Chris never responded, sorry. But I also got in a new battery this week with this same failure. The battery only had 53% of the maximum capacity, weighed about half of what a normal one did. I got my money back and the supplier didn't even want it back.
mayer さんによる
ok, no problem, just did it myself as i was thinking of returning the battery. yours sounds like a rip off. mine was not the cheapest on the market but also not the most expensive, and i am quite satisfied with it. would have returned it back also if it would have been like yours.
Lord Vader's Finest Rocketeers さんによる
14件以上のコメントを表示
