メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Aftermarket iPhone 6 screens with no polarizer?
Greetings! My team is tackling screen refurbishing and we noticed that there seem to be after market LCDs that do not appear to have a polarizer film between the outer glass and the LCD itself on iphone 6 units. Is this a common?
I assume this outer layer of glass is or has a polerizer built in (because you can see the picture) unless the whole assembly is constructed differently.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Actually people try to make a “privacy” screen and u wear special polorised glasses so only u can see the screen
さんによる
コメントを追加
1 件の回答
ベストアンサー
Firstly, we haven't done screen refurbishment in over a year (mainly started around when the 5/5S/5C were out, stopped just after the 6S came out), so this might be old knowledge, however I hope it is useful.
Depending on the manufacturer of the LCD, it may or may not have a separate polariser layer, most of the time it is built into the top layer of the LCD, compared to original ones. I don't remember this causing an issue during refurbishment, since there was no polariser film to peel up, we only had to worry about not scratching the top layer of the LCD. Most of the time, this meant it was actually easier to split and clean.
After a while, we also saw a number of screens for the 5/5S/5C where the touchscreen was built into the glass, instead of the LCD, and we did start buying iPhone glass with the touchscreen built in, to allow us to refurbish these ones. Not sure if these have become more or less popular in time since I don't do iPhone repairs anymore, but just thought I would mention it in case you have come across any :)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks Reece, looks like this is the case.
さんによる
コメントを追加
回答を追加する
krisfuqua さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 7
今までの合計 572
