Replace Hard Drive and retain all apps and data
Purchased 1TB SSD Hybrid 2.5" Hard Drive / Upgrade Kit
Need directions on how to replace hard drive and transfer all apps and data to the new drive.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's the guide on replaceingthe hard drive: MacBook Pro 15インチ Unibody 2.53 GHz Mid 2009ハードドライブの交換
Next, the drive will need to be formatted (GUID & Mac OS X Extended).
To do this you will need either a external enclosure or USB to SATA adapter or Universal adapter Universal Drive Adapter.
Enclosure http://www.ebay.com/itm/282243318167?_tr...
USB to SATA http://www.ebay.com/itm/152451267898?_tr...
Next, with the new drive in the machine, hook up the old drive with one of the options I gave to a USB port. Boot the machine - it will go to the external as that's the only system available. Go to Applications > Utilities > Disk Utility
Now, Format the new drive.
Next, You need an operating system, the same or higher than what you currently have. I'd go to Sierra. If you do not already have it on your drive, go to the App Store and download it.
Now install it onto the new drive. This will give you the new system and the repair option partition.
Next, reboot from the new drive. Hold the Option key down on reboot and select the new drive.
Now, this will initiate the set up procedure on the new drive. You will be given the option to Migrate from the old drive. Select it, migrate your choices and User.
Now reboot and you are set up.
このアンサーは役に立ちましたか?
To transfer the apps use Migration Assistant in your Utility folder either when you prep the new drive (the OS installer asks you) or afterwards.
過去 24時間: 2
過去 7 日: 9
過去 30 日: 13
今までの合計 120
