メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
締切られた回答
After spilled peppermint liquor the backlight from display doesnt work
hey , i´ve problem after a party on a boat club (i´m dj) someone spilled peppermint liquor into my mac it runs all is functionality only 1 usb port and the back light of display doesn't work !
what can i do
Update
ok i will try it and let you know what´s happend after cleaning the logicboard
thx for response
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Well
I hope that you cleaned and dried the MacBook for at least 72hrs before applying power.
Cleaning the logic board top and bottom (soft brush, contact cleaner &99% iso-alcohol) MAY still revive some of the functionality if there's no obvious burn or scorch marks on the logic board.
Otherwise you'll have to
  1. live with it as is you can add a usb port expander (self-powered is best but a PIA with a laptop)
  2. replace the logic board
  3. part out the machine
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,355
