メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
After replacement of front panel assembly red lines and green lines
Hi,
I recently disassembled a water damaged iPhone 6 because I wanted to use the screen for my personal iphone which had a cracked screen. Upon, disassembly the screen was functioning with the exception of the water damaged iPhone 6 dying and a blue screen exposed.
I did research on the blue screen issue and apparently it is a hardware defect because screws were placed too hard or software. I am hypothesizing the issue may be due to the water exposure to the logic board.
After, reassembling on the new phone I got the battery charging port icon & vertical red green lines on the screen. I thought it would be caused by the digitizer cables not accurately being connected properly.
Also, note that I have reassembled this iphone with no volume control up or down buttons the cable was severed upon the smash.
If someone could answer why the red vertical lines upon front panel reassembly would be occurring? I have included a picture.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@surf618 ,Stephen, Bad connection clean connection with Qtip dampened with 90% Isopropyl Alcohol reseat plug, damaged flex cable or connector(over bent ribbon/wires broke or pins bent/damaged in connector or on board), possibly the IC on the display is damaged or display defective, MB damaged. See the link below for more info. Good luck.
https://www.etradesupply.com/blog/how-to...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Stephen Sizensky さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 87
