Why is my battery is fast-draining?
Fast draining battery
Your battery is dying.
How long have you had this laptop? Normally lithium laptop batteries only last a few years under normal use before they start to go bad.
You will need to replace the battery and depending on how old the computer is it might still be under warranty.
Hope this helps and good luck fixing!
このアンサーは役に立ちましたか?
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 275
