メインコンテンツにスキップ
人気のGalaxy製品ラインを含むSamsungのAndroidベースの携帯電話の修理ガイドと分解情報です。
13156回答 すべてを表示
Recent scam came up blocking phone use involving a $500 fine from FBI
My Samsung Galaxy recently was hacked with a permanent showing of the above involving a demand of payment and a 96 hour deadline but no instructions to clear the notice or how to make the payment......
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thank you that was so simple
さんによる
コメントを追加
2件の回答
ベストアンサー
Don't back your machine up, and don't pay anything to anyone! Reset your phone as if you were starting it as a new phone. That should eliminate what's going on with it... and don't do any surfing with that phone!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Jeffrey Harman , You have picked up Malware/Virus, It may be time to do a factory reset, doing this will loose all the current Data on phone putting it back like new hen purchased. You did not state your model, if the reset procedure does not work for you, do a search for factory reset using your model#.
To reset your phone to default factory settings:
Press and hold the following button:
Volume up + Power + Home.
This will bring up a small menu.
Using the volume keys navigate to "Wipe data/Factory reset"
This option should restore your mobile to its default settings.
If you are going to continue to use your phone, say for Web check into virus/malware protection Good luck.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jeffrey Harman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 97
