メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why is my iPhone not turning
When I hold down the power button the logo shows for a couple second the it turns back off I have tried everything like resetting it and stuff. Also when I press down on the screen it makes a clicking sound like it's popped out and won't go back in
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
There are a few issues here.
First, the screen appears to be not sitting properly. Has the phone been dropped and does the housing have any visible damage (bent corners)? I ask this first as it may explain why your phone is always rebooting.
For the rebooting, it could be your battery is no longer holding a charge or perhaps the connector got knocked loose. You may also have some logic board damage but we must first eliminate the simpler stuff.
I would open up the phone and inspect for any obvious signs of damage or partial connections. Use this guide. Then I would replace the battery with a high quality replacement (like iFixit) to see if that solves your problem. You could also have an issue with the Lightning port but that is less frequent. If neither of those solutions help, then you may have a logic board issue. A good repair shop should be able to troubleshoot the problem or you can come back here with more details,.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Prince Bowdre さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 76
