メインコンテンツにスキップ
Appleの消費者向け人気ラインのMacBook Airの修理ガイド
4818回答 すべてを表示
My computer is typing the letter z constantly
my computer is typing the letter z constantly. I can barzely type this letter!z I took the key off, nothing is stuck. I reset the czomputer. It was an intermittent przoblem, but now seems permanent. Also, the letter z does not type when I press the keyz
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
I have the same issue with z key. What was the problem with yours? Did you get fixed? How much was it to fix. Please share any info you have. Thanks.
さんによる
i too havze this probzlemz.z funznyz is that it onzly types this letter after czertainz other letters: mz nz bz vz cz xz andz other letters are finez
さんによる
コメントを追加
4件の回答
最も参考になった回答
It definitely sounds like the circuits responsible for the z key are started to ground, causing it to be seen as permanently pressed down by the system. This could either be a fault in the keyboard (which is most likely), or could be a motherboard issue. I would first try and clean out the connector - if it's still pressed down, then run the computer with the keyboard unplugged, and see if the issue persists. If yes, then it is a motherboard issue. If no, then it is an issue with the keyboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try removing the back of the Macbook and disconnecting the keyboard from the logic board. Then connect a removable keyboard via usb. If the problem no longer occurs then you need to replace the keyboard of the macbook.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I plugged in an external keyboard and it worked then tried laptop keyboard and it works now too!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem on my macbook air 2015 model. How to fix it pleasee help my Mac condition is really nice idk why it is happening ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrea さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 59
今までの合計 10,939
