Start/Stop Button Not Working
Start/Stop Button Not Working. All other button function.
Can the start/stop button be replaced?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@alistair , Alistair, Use the disassembly guide below to take your watch apart and clean the buttons perhaps if need be then you will have access to change buttons. Use a soft cloth or Qtip dampened with 90% Isopropyl Alcohol to clean around the buttons and contacts. Good luck.
このアンサーは役に立ちましたか?
Hi, i have the same problem on my GARMIN Fenix 3, You think the solution is the same ?
Thanks
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 16
過去 30 日: 59
今までの合計 13,896
