メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 U2 ic Replacement
I have an iphone 6 that dropped in water, i cleaned the motherboard and it worked fine for a month. Then it started reboot sometimes and flashing on apple logo. I tried to restore and returns error 9. I search at google and i decide to change the U2 ic. I removed the old U2 ic chip and by fault i removed the two capacitors near this chip. Please see the photo below...
Can someone help me, is this two capacitors so important and i need to find others to replace or just let it like this and solder the new U2 ic?
I would appreciate your help. thank you!!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
The one at the bottom of the image is C1754 (0.1MF/4V/01005) and the top one is C1739 (0.01MF/6.3V/01005).
Are they necessary? You should be able to test your repair without them but if you are charging a customer for this repair, then you should replace them. Engineers put them there for a reason. They are easy to source (Digi-Key) and inexpensive.
These capacitors are used to filter the power rails from any "noise" on the line and they are put as close to the IC as possible. Considering that the Tristar IC is used for communications, I would say it is important to have them there.
If you are doing micro-soldering repairs, you really should have schematics and boardviews? There are free versions on the web or you could license ZXW Tools for less than 100$.
As an aside, you ask lots of questions and many repair techs invest time to give you thoughtful answers...yet you rarely upvote or select their answers. This isn't about just "points". It helps the many people who may find your question in the future because they have a similar problem. Seeing votes and selections gives them clues about which answers are helpful. Maybe the mods (@mayer @oldturkey03) should chime in here, I don't want to be out of line.
このアンサーは役に立ちましたか?
スコア 15
23 件のコメント:
@refectio Feeling a little used? Unappreciated? Welcome to the club ;-)
さんによる
@mayer ... just a modicum ;>)
さんによる
Good Job John!!
さんによる
Friend I really didn't notice that need to accept the answers. I go back to my previous posts and I will accept all answers. I really appreciate the other members help and I want to help others solve same problems. Thank you
さんによる
That's not a problem...
The point is to give guidance to those that search through the forum. If you don't feel an answer was helpful or solved your problem, there is no need to upvote or select; no one will take offense.
So...have you found the "free" schematics? I'll give you a hint, sign up at GSMForum. I can't imagine doing micro-soldering without them.
There is also a "free" version of what ZXW offers (interactive boardviews) although the real ZXW Tools is much better.
さんによる
18件以上のコメントを表示
コメントを追加
I have removed u1401 ic and you have right
See the photo what happened, some pins expanded and bridged. What a mess, is this situation repairable? What do you suggest me?
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
This board is extensively damaged. Was it worked on by someone else before you had it? The reason I ask is that I fail to see how reflowing, or even removing for that matter, could cause that much damage to the solder mask. It looks like it was scraped. If heat did this, then there was too much heat and I would suspect other damage as well to the surrounding area (and opposite side of the board).
The connections look okay but I believe it will be difficult to get solder balls to stay in place and not spread or spillover. You could always try but I wouldn't expect any real success.
さんによる
This board is water damage board. This chip has no glue around so water rolled below this chip, i didn't scratch the board. I removed the chip and i saw this. I have just cleaned the old solder nothing more
さんによる
That makes sense.
さんによる
No there is more to it. He seems to be wicking the board aggressively. Correct me if I'm wrong as this could be an illusion from a bad picture! As a result, the mask around the pads is gone and the copper traces are showing. Now if he tries to solder a new chip on, he is likely to have bridges and shorts. Same for the Tristar chip. He needs to cover the exposed traces with UV curable mask first.
In summary: don't wick pads!
さんによる
yes thats the point, the mask around the pads is gone and when i install new chip there are shorts and bridges. But U2 ic is not the same, the pads in U2 ic seems to be in good situation!!! I need to cover the exposed traces of course, i will come back when i finish this job
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
johnfl21 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 23
今までの合計 23,837
