メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
iSight cable broken. Solder and wiring info needed.
My iSight cable snapped right in half. The very thin red and green wires are lined up so I think I know the correct way to re-wire it but does anyone have tips on how to solder these super thin wires. I can barly strip them without breaking them.any help would be awesome as a new iSight cable is $50-$80 dollars which I dont have.Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Well, I would use a small soldering iron with a small tip and a fixture to hold the cable in place as well as a magnifying light. it can be done just have to be patient and prepared. The pinout as well as more information for the insight cable is here http://www.insanelymac.com/forum/lofiver... and here http://forums.applecentral.com/ubbthread... The information for the pinout that I got is
Pin 1 is the left most (has an chevron pointing to it). LVDS/iSight cable wire color in parenthesis.
Pin 1 (dark blue): connects to a pad on a 6 pin footprint for a chip that is not installed
Pin 2 (dark blue): connects to a pad on a 6 pin footprint for a chip that is not installed
Pin 3 (light blue, white conductor): USB D+
Pin 4 (light blue, purple conductor): USB D-
Pin 5/6 (orange): USB VCC (+5VDC)
Pin 7/8 (orange): USB GND
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks! Very informative info. The only problem is my iiSight cable has 2 red wires and the rest are green. So it's a little difficult to match up which green wires connect to each other.
さんによる
anthony g, may be this pic can help you a little better not the best but it shows the connector with the colors of the cable. http://htmlimg4.scribdassets.com/9bzpb6m...
さんによる
コメントを追加
can you re-upload the pic to see the pinout of the connector on the motherboard?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@oldturkey03 notice given
さんによる
コメントを追加
回答を追加する
Dirk Funk さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 4,371
