メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
Several problems after trying to replace iPhone speaker
So I recently followed the guide for replacing the speaker in an Iphone 6s. Not only did I think everything went smoothly but it almost seemed surgical. Used every proper tool, every screw and component was kept track of, and I didn't force my way through anything. Although after booting there seemed to arise several strange problems.
1. During the first boot after the installation, the phone was stuck on the apple logo which I was able to get out of by hard resetting. Weird, but didn't think much of it.
2. For a few hours the phone was working flawlessly but then it stopped charging at a certain point. I tried different cables and outlets but nothing has worked so far. Now it only charges when the phone is off.
3. In addition, even when the battery does charge, it loses its battery extremely quickly.
I find this to be very strange considering I didn't even touch the charging port, or the battery for that matter.
CAN SOMEONE HELP ME OUT PLEASE
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Just for clarification.
Was it the top earpiece speaker on the screen or the bottom loudspeaker connected to the charging port?
Do the charging cables plug in fully into the port?
If not then there is most likely debris inside the charging port that needs to be cleaned. You can use a tooth pick or straight pointy tweezers to clean it out.
Just make sure you don't bend the charging pins left to right, they can be pushed down slightly.
さんによる
It would be the bottom loudspeaker connected to the charging port. And yes it seems like the cables go fully into the port.
さんによる
コメントを追加
1 件の回答
ベストアンサー
When working on iPhone 6S and 6S plus, you need to discharge the phone, after you've removed the cables, before you put them back on. It's very possible you've damaged something. I don't think it's a board problem, which is good. It's likely that you've damaged the battery and or the Lightning dock. I talked with the folks at iFixit to put some kind of a warning....
Update (02/06/2017)
Obviously you haven't worked on an S model. Sorry, meant to write it in my post. You need to hold down the power button. Again, after you remove the display and power cables, before you put them back on
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
What do you mean by discharge? Does that mean wait until they have no power? Also I just wanted to mention I didn't really even touch the battery except when disconnecting its connection to the board. Is there a way to know which one? Because it does charge, but only when it's off.
さんによる
You do not need to discharge the phone. I've fixed thousands of them and never even heard of something so silly
さんによる
What do you think the issue could be?
さんによる
I've fixed 2 6s and a 6s plus just today.
I have never once discharged an iPhone 6s and I've fixed over 150 of them last year alone with almost no issues
さんによる
Same here. I've never done it on 6s and higher yet.
I've even plugged in a iPhone 6 display while the phone was on which was dumb of me. The phone recalibrated itself by doing a soft reboot.
Honestly discharging the phone is the same as like wearing an ESD strap to build a computer. ESD seems to 99% of the time never been an issue when it comes to building computers.
I'm pretty sure any flagship phone is designed to discharge itself quickly after battery unplug. Literally just 3-5 seconds of just waiting there is enough already.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Michael Shkatov さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 109
