メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
369回答 すべてを表示
Top microphone waterproofing - can a sim tray pin break it?
Hi. I accidentally poked the top mic hole instead of the sim tray with the pin. What an idiot! Mic still works fine, but does anyone have any information on the waterproof setup of the mic. Might I have compromised it? Is the waterproof device directly in the hole? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
[image|1016539] hi thanks again. I tried what you said but I can't see anything that says 'pressure' to test. Am I in the right place?
さんによる
コメントを追加
2件の回答
Post a pic, is the waterproof mesh broken?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi thanks for your help. From the outside of the phone there is no noticeable damage at all. So sorry I can't help with that. Would you expect to see that broken if it has compromised the waterproof?
さんによる
It it looks fine, then I wouldn't worry about it, test it by going into phone, type *#0*# and then click sensor. Find pressure and then press on the screen. If it goes up, it is waterproof. If not, then it probibly isn't waterproof anymore. If your confident, put it in some shallow water and see what happens.
さんによる
On brand new phones the pressure goes up slightly and then drops web release to lower than original number and then back up. Remember these are water resistant phones. Under pressure, be it water or air, either can get past the seals if increased beyond the point of the seal. Without pressure, water doesn't force it way past seals. With enough pressure even a submarine will leak.
FV
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes, it is the barometer. It says altitude and barometer, it is mainly used for weather but it should work for this too.
さんによる
I think the only real way to test it is to put it in water, but it should be fine if it looks fine.
さんによる
コメントを追加
回答を追加する
Matt Guest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,495
