メインコンテンツにスキップ
Lenovo IdeaPad, Yoga Series. Released October 2013, 13.3 inch screen, 8 GB RAM, 2 GHz CPU, 512 GB SSD.
15回答 すべてを表示
Is my Lenovo touchpad broken?
If I click on the lower right and left corners of my Lenovo touchpad nothing happens anymore. I can still use the cursor on the screen though.. I re-installed the driver/ restored a previous one but did not work. Should I substitute the touchpad ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
From your description it seem as though there is a problem with the touchpad.
Here is a link to the Ifixit guide on how to remove the touchpad.
Lenovo Yoga 2 Pro トラックパッドの交換
Here is a link to the Lenovo Yoga 2 pro service manual.
https://download.lenovo.com/consumer/mob...
If you scrol to p.61 you will find the part number for the touchpad (item #4 - 73040855).
If you search online using just the number you will get results for suppliers of the part.
Here are two examples. As you will find, the prices vary considerably. It is not a recommendation to use the sellers in the links they are shown just to give an idea of the prices. There are others that may suit your better.
https://www.impactcomputers.com/index.ph...
http://www.notebookparts.com/lenovo-idea...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
alessandro baldini さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 3,227
