メインコンテンツにスキップ
The LG G Pad 8.3 is a tablet created by LG Electronics Inc. that weighs 11 ounces, has 16 GB of storage, and has a 8.3 inch screen.
20回答 すべてを表示
Got new battery for lg vk810 let it go dead
I got a new battery for lg 8.3 vk810 accidentally I let it completely die now I can't get it to charge or turn on I tried the 20second thing but it still won't do. anything. Also my screen is very dim?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
lisasaunders528 "still won't do. anything. Also my screen is very dim?" so it does come on but has a very dim screen? Clarify this for us. A dead battery would not give you anything.
さんによる
I replaced the battery and was working fine for a couple of days but then accidentally. Let it die now I can get it to charge or turn on
さんによる
Sounds like you are having an issue with either your charging cable, your charger, or the charging port. Have you tried a different charger/cable?
さんによる
Yes I've tried different cable and charger box it will sometimes show me the LG screen but can't get it to go past that I just ordered a new charger Port with flex cable so I hope it's the problem.
さんによる
Also every once in a while I get a faded ring around the outside of the screen does that have anything to do with it or is that a hole new problem itself?
さんによる
コメントを追加
2件の回答
ベストアンサー
Got the new flex cable in and its working great thank you for your help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Try disconnecting the battery for a few minutes then replace battery and before turning it on plug it in and let it charge . Leave it plugged in for a day. see if this helps
just in case you need a guide
LG G Pad 8.3 Battery Replacement
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
It's a new battery I just replaced it. And I let it charge over night
さんによる
disconnect it then reconnect it before recharging . Connection may not have seated correctly . Check connection for dirt or lint
さんによる
Installed. New flex cable and port and is working great now thank you
さんによる
コメントを追加
回答を追加する
lisasaunders528 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 2,226
