メインコンテンツにスキップ
Gigaset Tablet freezing on me
The other day I went to turn my gigaset tablet on and it just stayed on the booting screen so I had to press the small reset button on the back to get it to work normally. When I did that I went ahead and did a factory restore to avoid that happening again. But few days ago I was on Tumblr on chrome app and my tablet froze and would do anything so I hit the rest button again and it started up normally after. Just a few moments ago it did the same thing, froze up on chrome app while trying to use Tumblr. I don't know it it's tumblr causing it but don't really know why it's doing this. Any help would be appreciated.
Update (01/30/2017)
Just tried turning it on and I wouldn't start till I pressed the reset button and tried again. Anyone know what I can do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi! If you look at the top left corner of your screen when it freezes, you might see that you're getting an email from someone or an app is being updated. You can choose to get your updates only when your tablet is sleeping (not shut down). You can also get a cleaner app like PowerClean, which will help reduce the number of apps running in the background when you're not using them. One thing that does NOT help is trying repeatedly to get the screen to respond when it freezes. That can cause your tablet to freeze up & refuse to respond again until you shut it down. It's frustrating but all devices freeze occasionally...just wait a minute or so. If you don't want to wait, put the job to sleep and check your notifications for clues as to what's causing the problem. I hope this helps. :-)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I got my tablet a year ago and can't use it. the electric power cord dose not fit, it is to small to small.
さんによる
コメントを追加
回答を追加する
Dave さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 2,906
