メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
How to fix dented iPhone corners?
I have an iPhone 5s screen which was dropped and the screen was shattered. The phone was dropped on the top corner and is now dented slightly inwards, this is causing a problem when trying to replace the screen as it isn't sitting properly in the frame. I don't want to force it in as I don't want to break the new glass. Are there any suggested methods to re corner the frame?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
You could see if a local store has a tool in stock called a gtool. This is used to bend out dented frames.
Or you could shave down the dent with a metal flathead screwdriver.
さんによる
コメントを追加
2件の回答
You could always buy an new chassis for the phone. They can be a little pricey but also allows you to customize the phone with a wide selection of colors. Check out iphone4parts.com. I will post the link that goes directly the part your phone uses.
http://iphone4parts.com/shop/iphone-chas...
Here is one much cheaper on ebay.
http://www.ebay.com/itm/New-Space-Gray-i...
Alternately, you could search for other bezels or chassis on ebay.com, amazon.com and also aliexpress.com.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This tool works great on iphone and ipad corners https://youtu.be/pea1NOk2UKQ
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stelios Sgoutas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 9,722
