How to fix dented iPhone corners?
I have an iPhone 5s screen which was dropped and the screen was shattered. The phone was dropped on the top corner and is now dented slightly inwards, this is causing a problem when trying to replace the screen as it isn't sitting properly in the frame. I don't want to force it in as I don't want to break the new glass. Are there any suggested methods to re corner the frame?
You could see if a local store has a tool in stock called a gtool. This is used to bend out dented frames.
Or you could shave down the dent with a metal flathead screwdriver.
Stephen Elliott さんによる
