メインコンテンツにスキップ
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
86回答 すべてを表示
Oil light flashes on cold starts
Car is an 04 jetta tdi.
On cold starts the oil light flashes and will stay on for the remainder of the time the engine is running. If I run it for a few minutes to warm up the car then turn off the car, and turn it back on, the light will go off. The oil level is fine and this is the first winter that I'm dealing with this. Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Put a piece of black tape over the light, or just pull the bulb. The car is just throwing a tissy fit
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
And if you have a block heater, plug it in during the cold winter months. Could solve the issue without any tape necessary
さんによる
I'm sorry, remove the bulb that tells you there's a problem with your oil? Car is throwing a fit? Please never ever give advice ever again as it's quite possibly the worst advice I've ever heard.
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 242
