My blackberry is overheating all the time
This may sound crazy (or not) but this things overheating
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like the battery went rogue.
How long have you owned the BB for?
This problem usually happens from your BB being charged in a staggering time line. Plug in for 20 minutes, use for 35, plug in for 5 minutes, use for 10 min.
Doing that and ripping the charge cord out fast (everyone has done it at least once) causes sub surges. That energy is sometimes stored waiting for a another kick to ignite (plugging it back in) so to speak.
Take the BB battery out and plug in your device. Some BBs will operate without battery. Cab drivers used to do this all the time. If it heats up while battery is out, then your device chip and board is causing the over heating. Dropped, moisture, sitting on it time and time again, pocket lint, dust ...all play a role in a device's lifeline.
Shaun
a.k.a. @SinisterCaine
このアンサーは役に立ちましたか?
Try it with another battery, this kind of battery they overheat once they are too old or bad.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 3,642
