メインコンテンツにスキップ
The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
11回答 すべてを表示
My blackberry is overheating all the time
This may sound crazy (or not) but this things overheating
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like the battery went rogue.
How long have you owned the BB for?
This problem usually happens from your BB being charged in a staggering time line. Plug in for 20 minutes, use for 35, plug in for 5 minutes, use for 10 min.
Doing that and ripping the charge cord out fast (everyone has done it at least once) causes sub surges. That energy is sometimes stored waiting for a another kick to ignite (plugging it back in) so to speak.
Take the BB battery out and plug in your device. Some BBs will operate without battery. Cab drivers used to do this all the time. If it heats up while battery is out, then your device chip and board is causing the over heating. Dropped, moisture, sitting on it time and time again, pocket lint, dust ...all play a role in a device's lifeline.
Shaun
a.k.a. @SinisterCaine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Try it with another battery, this kind of battery they overheat once they are too old or bad.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
john さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 3,602
