メインコンテンツにスキップ
Released 2015 Model Number: POLSP01W
66回答 すべてを表示
Red light is blinking
My Polaroid SNAP wont print out pictures. The 3rd red light is blinking. Do I need a SD card that way it can work? Someone please answer ASAP.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
3 件のコメント
I have this problem too, how did you solve it?
さんによる
i also have this problem. how am i supposed to take pictures?
さんによる
Me too ,how do you fix it?
さんによる
コメントを追加
4件の回答
最も参考になった回答
@anonymous__ ,Anonymous, Find below links to troubleshoot your Polaroid SNAP, If the camera is still under warranty and problem persist after using the trouble shooting guide link #1 and your manual link#2, then use link #3 for contacting Polaroid support and warranty. Good luck.
Polaroid SNAP Troubleshooting
https://www.polaroidsnapcamera.com/skin/...
https://www.polaroidsnapcamera.com/snapc...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
No you do not need an SD card to take pictures. You can either have the film OR the SD card. Or both! The red light is just telling you its missing whatever the red light is flashing in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I think I know how to fix the problem. The camera is very picky depending on how you put the film in make sure the part that says sink zero ink is facing downwards and the blank part should be facing towards you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this same problem. It was an error with the paper, I had to keep playing with it a little. I bent the stack of paper a little the other way to straighten it out as it was bent just slightly and then i pressed hard on the back when I closed it. I think that helped get the paper in place…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anonymous さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 34
過去 30 日: 132
今までの合計 29,466
