I would try these steps in order.
1- Open the phone, take out the board and check ( J1111 ) if it's damaged
or shorted repair it. Try to restore the phone without connecting the
front camera flex.
2- Check ( U0301 ) IC if it's cracked or damaged, resolder or replace.
3- Take out the board and remove the metal sheild over the NAND chip
(the U0604 chip in the picture). check if ther is any damaged component
around the chip, or if there any water damage (clean it ).
Check if there is any shorted (capacitor, resistor, coil) around the chip
then replace it.
4- resolder the NAND chip using heater (use the same tempereture you
use usually to remove ICs). heat for about 15 seconds and don't forget
to protect the ICs around the chip.
5- Replace the NAND chip but be carfull ( don't heat to much cause you
got the CPU in the other side). Don't go to this step befor being sure
that you did all the previous steps and there is no problem connecting
to Apple server.
5 件のコメント
I am very confused at your problem. The title says backlight sensor is broken, error 4005 is a restoration error and I don't know what you're exactly asking. Is it about how to recover data, fix the screen or what?
Brandon Hollenback さんによる
Yes. I'm not new to this, have tried everything
Carsten さんによる
You said "Yes" but to what portion of my question?
Hi Guys
Thank you very much for your swift answer, this is great that you are so fast in helping out, but you are speaking russian to my knowlegde of where to find all the components that you are talking about. I would be eternal greatfull if i could get pictures of them so that i can take the board out and examin it properly.
thanks
my spelling is properly not the best !
Carsten さんによる
Hi Brandon
This is about geting this phone to work again. is this posible, have tried anything.
Carsten さんによる
