Reversing light comes on occasionally when breaking
Since having my reversing lights repaired at a garage, they come on occasionally when I break. Drivers behind me are worried! I can't recreate the fault when stationary tho. Help!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If the work was carried out recently to repair the reversing lights by a garage, there should be some sort of guarantee on their workmanship, provided by them, even if it is only for 30 days etc.
Take the car back to them and explain the problem and show them as well (hopefully the problem will happen when you do this) and ask them to check it out, as it is causing problems for you..
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 12
過去 30 日: 19
今までの合計 128
2 件のコメント
does the reverse light work when you have it in reverse gear??
pascal molenberg さんによる
Yep, reverse light works when in reverse gear and I can see it when it's stationary
sophie さんによる
