voice is not working
out going and incoming calls are working but the voice out put is not working
It's definitely in your handset. Either someone pulled a prank and put tape or something over the receiver (I've responded to way to many calls where the user was pranked) or the receiver has broke lose which requires replacement. If replacement isn't an option you can open up the handset, find where it's broken and solder it back together.
Any handset will work if it's a corded, if it's cordless you'll have to purchase a whole new base/handset or an identical handset. Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
