メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
Everything Works but the Controllers
For the past few days, I've had issues with my Xbox 360 S.
It started with turning off unexpectedly in the middle of using an app (ie Netflix or Youtube) - it would beep when it shut off as though the button had been touched. Sometimes I could restart and everything would go as normal. Other times it would shut down again immediately, taking a few minutes before booting normally. That went on for a couple days. Then it worked fine for the past 2 days.
I tried to use it today expecting everything to work. Everything did work -- but the green light around the power button never lit up. The console won't respond to any of the controllers. I'm left stuck on the Xbox Live login screen. The power bar's light is green and stays green and the optical drive still opens and plays all my DVDs.
I have no idea what is going on. Please, someone help me figure this out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hey mate, I have seen similar issues to this and if its what i think it is, it can be messy. Issues like this is caused by cockroches getting into the xbox. They like it in there due to it being warm. Open it up (if not under warranty, if it is still under warranty take it back) and look at the mother board and especially the front power board. Look for eggs, cockroch droppings and pee. If there is any, clean it off with some rubbing alcohol but be careful of the SMD components on the boards. If this isn't the issue, let me know and I'll help you out if i can.
Zakk
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tika T さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 77
