メインコンテンツにスキップ
LCD does not turn on
I recently replaced the digitizer on and iPad 2. After the repair the iPad turned on for about 3 seconds the turned off. I plugged it in, but nothing happened. I tried a hard reset and that didn't work. I then went to check if iTunes recognized it, and it did. After that I reseated the LCD connecter and it still doesn't work. Please help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Did you isolate the battery before removing the LCD? You may have damaged the backlight circuit on the logic board. Check L2200 to see if you have continuity across the filter. If you do, check the voltage and work your way back to D8228.
Look for the schematic on Google to see the boardview.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
No I did not isolate the battery. The video used some sort of special tool that I don't have, so I tried to separate it with my spudger, but it didn't work.
さんによる
Would I have to replace the backlight circuit if this is the problem?
さんによる
You can make your own isolation tool by cutting a pick just like this (Battery Blocker).
Usually, the filter blows. So you would need to replace it with this(iPad 2 / 3 / 4 / Mini / Mini 2 Backlight Filter L2200). If the filter is good (measures 0 Ohms), then it could be the diode or (rarely) the coil. Of course, it could be something else as well. You need to find the schematic, start probing and then think about where the source of the problem is. You can also comment back with your findings.
さんによる
コメントを追加
回答を追加する
Alec Thompson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 60
