メインコンテンツにスキップ
The Brother MFC-240C is an all-in-one color inkjet printer.
29回答 すべてを表示
MFC-240C does not print - despite fresh cartridges and multiple purge
My Brother MFC-240C prints in black, but in none of the colors. I have already installed new original Brother ink cartridges, and executed multiple Normal/Power Purge runs (using the Maintenance Mode as described in the service manual, chapter 9 / 9-43). The problem persists.
Can anybody help? Has anybody successfully disassembled the printer, and cleaned manually the ink supply tubes and/or the printing head?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Print head could be clogged and needs some cleaning. Check Youtube for videos on cleaning...Ink have expiration too, it could be old and dry.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you for your suggestion. It is absolutely correct. I have disassembled the entire printer with the help of a detailed service manual for MFC-240C. This is necessary as the print heads of Brother inkjet printers are located deeply inside the printer. Cleaning the printhead with distilled waters, followed by some purge operations (in the printer's service mode) helped.
All colours appear again perfectly. My old printer got a second life :)
さんによる
You are welcome. Where can I see the service manual for MFC 240-C, I hope you don't mind?
さんによる
コメントを追加
回答を追加する
Markus さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 15
今までの合計 2,000
