メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Why is my battery percentage not changing?
I had a touch IC repair a week ago, and now my phone restarts on its own and yesterday it stopped showing actual battery percentage. I don't know if it's actually charging or not, but it stayed on 5% through the night. I tried a hard reset and it's not working either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
First, definitely take it back and have them look at it under warranty.
Are you /were you using an aftermarket charging cable? If so that aftermarket cable could've easily damaged a chip on your motherboard (called tristar) that is responsible for charging your device. This is very common.
I would have them first test a new battery (original preferred).
If that doesn't fix it most likely a damaged tristar ic. I might also consider having a motherboard specialist inspect for physical damage done to board possibly during repair....such as long screw damage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yasmine Mehrez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 455
