メインコンテンツにスキップ
モデル番号A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544回答 すべてを表示
Can I upgrade my mid 2010 MBP to a 2.8 GHz Core i7 logic board?
Hi guys,
my mid 2010 MBP is having some problems with the video card so I have to replace the whole logic board and since I have a 2.53 GHz Intel Core i5 processor I was thinking to upgrade it but I have some doubts: I did some research and officially looks like there are only two logic boards for my Mac:
- 2.53 GHz Core i5 (I5-540M), code 661-5472
- 2.66 GHz Core i7 (I7-620M), code 661-5526
But I also found out something about a 2.8 GHz Core i7 (I7-640M) processor, which looks like it works for my version but I'd like to be 100% sure.
Looking at this page I understand it should be fine, but in this Apple topic there is no official documentation so I don't know...
Could pls help me clarifying this doubt? Thanks a lot!
Alessandro
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Yes!
Assuming your A1297 is a M2010 you should have no problem swapping in the i7 logic board.
Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Alessandro, did this work? I have the same problem and question - I need to do a replacement, and would like to upgrade to 2.8GHz to avoid getting a logic board with a faulty GPU. Would love to know if this worked for you. Thanks!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi Jennifer,
I'm sorry but I can't help you because at the end I got a 2014 MBP. The reason was I couldn't find that specific logic board I was talking about, it was always out of stock, and anyway it had a price of 700/800 bucks, which is crazy considering that is 7 years old.
The others should cost around $ 400-450.
さんによる
They all have a NVIDIA GeForce GT 330M, so it is no more reliable. However, it is very likely that the current logic board you have can be fixed by someone who does macbook component-level logic board repair, as the culprit for the GPU issue is most likely the fault of a tantalum capacitor (reference designator C9560) that becomes unreliable over time, shorting the GPU's power supply to ground intermittently. It's a very common issue for 2010 15" MacBook Pros with GPU/kernel panic issues
さんによる
コメントを追加
回答を追加する
Alessandro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 2,189
