メインコンテンツにスキップ
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
My iBook G3 Is Having Keyboard Issues. What Can I Do?
Dear iFixit,
I am having Some Issues with the keyboard. There are (about half of it) some keys one the keyboard that if i press nothing shows up, not another letter, nothing. I wanted to reset the iBook to factory settings put read some internet articles and i do not hafve any restoration disks, i got it used. Is there any other way to reset the laptop without erasing the OS? I do not care about the information.
Thank You
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
please help me :)
さんによる
Thank YOu, That Did NOT work, (Thank You For The Advice) but... IS there a possible way for resetting the laptop to factory settings without any Tiger Discs?
CaveCanem
さんによる
コメントを追加
2件の回答
ベストアンサー
Since an external keyboard would not work I suspect your problem is hardware related. I know of no way to reset to factory settings without the operating system disk. It sounds as though something may have been spilled on the keyboard or possibly a problem with the logic board. One other easy check you can make is to remove the keyboard and insure the ribbon cable and connector are in good condition and making a good connection. Link provided to help you. Good luck.
iBook G3 12" Keyboard Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Try an externel USB keyboard to check if the troubles are software related. Any USB keyboard will do, even a PC one. If that works you will have to replace your build in keyboard.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
good answer +
さんによる
Thank YOu, That Did NOT work, (Thank You For The Advice) but... IS there a possible way for resetting the laptop to factory settings without any Tiger Discs? CaveCanem
さんによる
コメントを追加
回答を追加する
cavecanemantiquestore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 838
